New D2 owner
Old Sep 17, 2017 | 09:17 AM
R2 D2's Avatar
5th Gear
Default New D2 owner
I am the proud owner of a 2003 D2. It has about 96000 miles. I had done a little research on the vehicle before buying but despite that (ha ha) I still went ahead and pulled the trigger. Yeah, it's a 2003 but it's out of the death VIN range (although I've read that doesn't mean I'm safe) and one of my first purchases was a locking CDL. I bought replacement fluids for the brakes, power steering, diffs/transfer case, coolant, engine, transmission. I've a headgasket kit that I will install this winter. New Falken 245/75/r16 tires that I am very pleased with. Also bought a new coolant reservoir and 185 thermostat, brass fill plugs for the diffs, replacement dash/climate control/clock light bulbs, upper and lower ball joints, Terrafirma 2" lift kit, fuel purge valve, and O2 sensor.
Old Sep 17, 2017 | 09:19 AM
R2 D2's Avatar
5th Gear
The brake pads and rotors look fine. The paint is in decent condition. the body has no dents. It has the 2 jump seats in the trunk which is cool but not as cool as the inboard facing seats like in old Land Rovers and Toyota Land Cruisers. I don't think it's an SE as it has no decals on the side marker lamps on the front fender and no leather or wood trim.
Old Sep 17, 2017 | 09:23 AM
R2 D2's Avatar
5th Gear
It does throw 2 codes: Random Misfire and Misfire Cylinder #4. When I have more time, I will have to investigate further. It sounds a little rough at start up but once warmed up, the engine sounds fine. There is a hairline crack in the driver side taillight. The slightly larger tires rub on the mud flap a little. The front bumper is cracked.
Old Sep 17, 2017 | 09:27 AM
R2 D2's Avatar
5th Gear
I originally planned to put the lift kit on but now I wish I hadn't bought it. Looking back I think I would have spent that money just towards long travel shocks. Even at stock ride height (and without CDL), I find the vehicle to be very capable. I have no intention of turning it into a hardcore off road vehicle but still want it to be able to take it most places without getting stuck. There are a lot of dirt trails where I live (southwest GA).
Old Sep 17, 2017 | 09:30 AM
R2 D2's Avatar
5th Gear
Looking forward, I plan to concentrate on maintenance. i would like to rebuild the steering system and replace any suspension bushings as needed. I will start replacing seals next year and replace all U joints with greaseable ones as well.
Old Sep 17, 2017 | 08:59 PM
MAALI132's Avatar
i am ella. nice to be here. eager to be friends with all of you.
Run33
May 11, 2015 09:43 PM
Chief
Sep 23, 2008 02:36 PM
jwinck
Sep 19, 2008 12:37 AM
desh72
May 5, 2007 12:03 AM
ctcnewton
Feb 18, 2006 12:32 AM
