New to forum
read this. keep in mind you are looking at a D1 not a D2
https://landroverforums.com/forum/di...scovery-21328/
- Replaced transmission cooler lines (leaking)
- Replaced oil cooler lines (leaking)
- Replaced oil pan gasket (leaking)
- Replaced 4 tie rod ends
- Replaced coil springs and shocks (sagging)
- Replaced suspension bushings all the way around
- Replaced head gasket
- Replaced serpentine belt
- Replace window regulator and motor on driver door
- Replaced window regulator roller on passenger door
- Removed sagging headliner, trash fabric, primed/painted with chalkboard paint
- Replaced both front power seat switch covers (broken)
- Replaced glove box light assembly (broken/shorting and blowing fuses)
- Replaced cruise control hoses (cracked)
- Replaced steering damper (original never replaced)
- Replaced fuel filter
- Replaced fuel pump (died)
- Filled swivel ***** with one-shot grease
Stuff that needs attention:
- Leaking steering box and hoses
- Rotors, pads
- Wheel bearings (repack and/or replace)
- Whatever else comes up
Most of the work above I have done myself, saving thousands in labor charges.
So, consider the fact that you will be purchasing a great vehicle (IMO) that will require regular maintenance and repairs that can cost $$$ if you are not willing to do the work yourself.
With that said, I have no regrets. I love my Discovery.
MuddMouth
09-30-2010 10:30 PM
m4ver1ck
07-22-2009 08:03 PM
