Newbie D2 owner!
Old May 3, 2021 | 06:55 PM
andino's Avatar
Default Newbie D2 owner!
Hey all! I've wanted a disco for a long time and finally took the plunge! Picked up this really clean 04 D2 SE in Giverny Green about a week ago.
So far, I've swapped the thermostat which was stuck partly closed with a 180F low temp motorad unit since I the Britpart one from lucky8 was backordered. Wanted to swap it ASAP since my temps were around 225F around town and 218F on the freeway. Also did an oil change, spark plugs, wires, and coil packs since I had some misfire codes pop up on the drive home. The truck recently had a head gasket and valve job done along with a water pump so hopefully things will be calm for a bit before some more work is needed. Next up on the list are to flush the brake fluid, change the t-case and diff fluid.
Hopefully will get some time to put some new AT tires on and a 2" lift in the near future. So far, the truck has been great and just needed a little loving to get things running smoothly. The seller had all the [size=13px]maintenance[/size] records back to the original sale! Took some time to find the right truck but glad I wanted for this one.
rovernoy
Aug 24, 2011 07:14 AM
GandAautoLLC
Aug 18, 2011 06:29 AM
BigG-UK
Feb 15, 2009 05:55 PM
robertl
Aug 20, 2005 11:07 AM
gwelland
Feb 9, 2005 04:16 AM
