Dream Garage setup
Old Nov 17, 2016 | 11:33 AM
  #21
OffroadFrance's Avatar
It's looking good AR, let it dry out well and slap the epoxy down ............ job done
Old Nov 17, 2016 | 09:02 PM
  #22
Thanks, epoxy is going down in the morning. So it's heading down the right path I hope
Old Nov 18, 2016 | 05:24 PM
  #23
Took out the wood half arsed workbench and plywood wall covering. Got the floor epoxy done. Tomorrow I'll get the shelves painted and relocated to the work room. I'll also paint the big white squares to match the other walls.
Old Nov 18, 2016 | 06:37 PM
  #24
ihscouts's Avatar
Even better with the fake bench and funky plywood gone, looks good Chief!
Old Nov 18, 2016 | 07:11 PM
  #25
Funky plywood had been repurposed to expand my attic flooring.
At Costco I picked up 3 4ft LED shop lights, two for the main area and one for the little work shop. I might add two more to the main garage area if they clear the door
Old Nov 19, 2016 | 03:34 PM
  #26
AR, once the floor has cured you could hold a party in there first and use it as a dance floor then afterwards tell all the neigbours to F___Off and let you get on with your garage and workshop. You would be like me then, a real Doc Martin abrupt 'bears breath'
Old Nov 19, 2016 | 08:58 PM
  #27
Went in today and decided that I want to do a gloss clear epoxy coat so after we finished installing the new LED shop lights we got to work on that. Then it was let it dry time. So we started moving the rest of the house. I'm exhausted and enjoying a blue moon. Tomorrow it's ground hog day and do it all over again.
Old Nov 19, 2016 | 09:11 PM
  #28
In the back work shop the shelves will be getting torn out. The cabinet shelves from the back wall of the garage will be mounted on the wall.
We have a lot of left over ceramic tile that came with the place so we are going to tile my work shop for practice.
A computer work station will be there with a wall mounted monitor. A 6ft work bench and stool with overhead LED lighting.
Also going to do a cover for the hot water heater in the corner
Old Nov 20, 2016 | 08:18 PM
  #29
The gloss coat was a good call
Had to start moving furniture though today so work on the garage hit pause for a minute.
Old Nov 23, 2016 | 01:07 PM
  #30
Gloss is good as it helps in cleaning the surface of spills etc and also reflects the light better.
"Had to start moving furniture though today so work on the garage hit pause for a minute."
Argh, that's what the wife is for eh
