getting in gear
Okay so my '01 has died..
head gasket finally went.. So I pulled the brand new battery I had just put in it and returned it. Well now I need to move from where it is into the garage until I can part it out, sell it, donate it.. etc. How do I get it into neutral to push it.
Should work fine. If you drive it in the engine RPM will probably search for a minute. If you push it in, put key in position 2 ( all dash lights on) step on brake and put it in neutral.
If the batt posts are different and don't line up properly just rig it to where it is just connected or touching )turn on key but don't try to start it. then foot on brake and neutral then push.
A battery charger hooked to the cables would probably work for pushing.
Rsbuz
LR2
Sep 6, 2014 12:52 PM
Lee1140
Dec 1, 2009 10:17 AM
