getting in gear
Old Oct 7, 2013 | 10:13 PM
WillRove's Avatar
Default getting in gear
Okay so my '01 has died.. head gasket finally went.. So I pulled the brand new battery I had just put in it and returned it. Well now I need to move from where it is into the garage until I can part it out, sell it, donate it.. etc. How do I get it into neutral to push it.
Old Oct 10, 2013 | 08:13 AM
slabrat's Avatar
Two ways : Put a battery in it, Or remover cover from gear shifter and remove solenoid that won't let it shift.
I would take a battery out of another vehicle and use it then put it back.
Old Oct 10, 2013 | 09:40 AM
WillRove's Avatar
Okay. I have my other car chrysler pacifica has a group 72 battery... can I use that? I just need to move my disco from the driveway to the garage.. so literally like 15-20 ft..
Old Oct 10, 2013 | 10:42 AM
slabrat's Avatar
Should work fine. If you drive it in the engine RPM will probably search for a minute. If you push it in, put key in position 2 ( all dash lights on) step on brake and put it in neutral.
If the batt posts are different and don't line up properly just rig it to where it is just connected or touching )turn on key but don't try to start it. then foot on brake and neutral then push.
A battery charger hooked to the cables would probably work for pushing.
Old Oct 10, 2013 | 11:28 AM
SSL9000J's Avatar
If you're parting it out anyway, remove the driveshafts & push it.
tylor36
Jun 12, 2013 06:58 AM
CrcdiscII
Mar 16, 2012 09:03 AM
bcolins
Jun 10, 2011 11:36 PM
Lee1140
Dec 1, 2009 10:17 AM
