Insulating a garage door
Old May 5, 2017 | 05:29 PM
It was chilly out today so I didn't bother we are having a cool streak for the next few days it looks like so. Gotta wait a bit
Old May 5, 2017 | 09:23 PM
number9's Avatar
Exterior color of door?
My white doors never get warm/hot to touch with direct sun during summer afternoons w/o insulation. Insulation would obviously help prevent some cooling/heating loss. I wouldn't overthink your alternatives to much unless door is dark color and gets sun 12 hours a day.
How's the insulation above garage ceiling and roof above?
Have a similarly sized portable a/c with heat pump in my 2x garage will drop/raise temps and lower humidity but a bit expensive to run. Air intake/exit needs a hole. The water collection tank needs to be emptied frequently or a drain plumbed.
Old May 5, 2017 | 10:04 PM
It is beige. Good insulation above as well.
I know it's not a 100% solution but if it makes it livable it's all good
Old May 6, 2017 | 05:49 PM
TOM R's Avatar
White paint makes a huge difference, silver also
Old May 6, 2017 | 07:22 PM
Yeah but it matches all the trim, way to lazy to repaint the whole house
Old May 8, 2017 | 05:31 PM
OffroadFrance's Avatar
AR, try 2" thick polystyrene sheet foam insulation board and glued on with spray glue used for carpet tiles. It really depends on what U value you are trying to achieve. You can also paint foam sheet with either emulsion or gloss paint. The more expensive option is the same type of foam sheet but closed cell type.
Old May 28, 2017 | 05:53 PM
Basically going for the most bang for the buck. I was hoping to work on this over the long weekend. Instead, I diagnosed the AC failure in the Expedition, the low oil pressure light on the Saab, replaced both front shocks and fabbed a exhaust system on the Expedition.
Oh lets not forget the LR3 and it's park assist going insane. I need to go back to work to relax...
Old May 28, 2017 | 07:05 PM
TOM R's Avatar
Lr3 common park assist is short in front bumper sensor harness , where harness comes through rad support, chaffed wires, passenger side, iirc pull head lite to find it , may require pull bumper skin, a search will show it unless u have a code
Old May 28, 2017 | 08:14 PM
Both rear outer sensors, Gap tool was the best investment.
jfall
May 11, 2017 11:37 PM
troubled
Jul 19, 2009 08:26 AM
mummra
Apr 26, 2008 02:11 PM
Doak
Apr 21, 2007 02:01 AM
jgarner
Nov 5, 2006 05:13 PM
