This is the problem with underseal
Old Feb 21, 2018 | 03:47 AM
OffroadFrance's Avatar
Default This is the problem with underseal
Car blogger reveals how water can get trapped in vehicles | Daily Mail Online
Underseal masks the rubber water evacuation bungs which should be removed periodically, say every year, to release trapped water in the sills and frame/chassis rails. Thankfully on D2's there are only the sills to worry about but flaking rust can block the frame/chassis rail water release holes causing the frame to rust from the inside out. The worst condition is obviously the monocoque chassis on modern cars after they have been undersealed.
Old Feb 22, 2018 | 12:09 AM
number9's Avatar
Underseal
That is more apt to happen after leaving the factory when the vehicle have been treated by typical shyster dealers or other dumb *** undercoaters.
Normal dust, small road debris and tree dropping can cause the drainage blockages if normal drain clearing is not complied with.
If you don't care for your plumbing you might get hosed.
Old Feb 27, 2018 | 04:01 AM
X1 ............ ya gotta keep ya holes clear or ya can get a build up
landymanderby
Defender
Sep 4, 2017 08:28 AM
Fredzzz
Oct 11, 2013 11:39 AM
XxRoverAllOverxX
Mar 23, 2012 04:49 AM
