FC 101 powertrain swap
Unless it's been modified, that would be a 109. The SIIA (as well as the SIIB) FC's were on a 109 chassis.
Have you checked to see what's under the FC? The IIA's came from the factory with Rover diffs, though some had ENV rears. IIB's had ENV front and rear. If they are ENV's you'd be down grading putting disco axles under it.
Even if it's Rover axles you'd probably be better off just putting in HD half-shafts rather than installing Disco axles.
It doesn't look like the original gearbox from the pic.
SIIA FC's in good shape are pretty rare.
I got it wrong when i posted. it is a 109.
I;m going to research the axles. I'm not using the disco axles.
i"ll post some pics of the underside and axles soon.
I'm using the intire disco drive train. and my boss told me that the frt and rear axles have been upgrade with HD axles from rovers north.
Land Rover collector
Jun 28, 2006 12:13 PM
