Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
1991 3.9 Hunter engine issues
Old May 2, 2021 | 10:09 AM
G Reeves's Avatar
Default 1991 3.9 Hunter engine issues
1991 RRC 215k miles 3.9 engine running the 14CUX. Engine will fire right up and idle no issues steady as a rock, rev to 5k no problems no hesitation. When in gear Hi or low it does not matter will not get over 1300 rpm. it will then drop to 800 rpms and then pick up to backto about 1300 and will do this. Let off the throttle to 1200 and it will drive. Bury the the throttle and it just dies.
Have cleaned the maf, no improvement. Have swapped the maf still the same any pointers on where to go from here?
Thank you
Old May 11, 2021 | 09:10 AM
Best4x4's Avatar
Any fault codes from the little code reader?
schwaggy
Jan 29, 2019 10:42 PM
MarineLandRover
Dec 6, 2013 04:51 PM
Chris-bob
Oct 5, 2010 12:05 AM
krigsmakten
Sep 30, 2009 02:01 PM
bowser881
Feb 2, 2009 01:30 PM
