Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Fault finding electrical and EFI
Old May 1, 2021 | 08:33 PM
RoverDad's Avatar
Default Fault finding electrical and EFI
Anyone experienced and understand running the Rave Electrical & EFI tests and results?
Issue: Nonstarter - Rave pg. 819, LTV test results:
T1: Good. Spark strong at HT and plugs
T2: V1 = 12.6v
V2 = 12.4 w/ ig off : .3v ig on
V3 = 12.4 w/ ig off : .3v ig on
V4 = 0v
According to pg. 820 these results are problematic and may be causing the non start.
Pg. 820 states low volts at V2 & V3 indicate possible bad Ignition Switch.
I've installed a new switch returning same results.
T3: Coil & amp are new and pass.
T4: Ohms at Dist good.
T5: Passes rotor arm test.
EFI tests so far accomplished from Rave pg.218:
(Rave 1987 model tests applied to our 1990 as Rave 1990 procedures are not listed)
T1: good
T2: good
T3: good
T4: good
T5: I don't understand
No further EFI testing yet completed.
Grounds at Chassis, Dist, Coil, Bonnet, & under seats all clean and confirmed.
Old May 2, 2021 | 06:59 PM
RoverDad's Avatar
Tune Resistor test result with battery connected:
W/ ecu clip off : 3.89 ohm
W/ ecu clip on : .878 ohm
Tune Resistor test results with battery disconnected:
W/ clip on : .99 ohm
No voltage at coil with ignition on or off yet HT spark looks strong.
How can this be? Again:
V1 = 12.6v
V4 = 0v
Don Neville
Mar 9, 2022 10:20 AM
Tommyblack97
Feb 27, 2021 05:00 PM
Brock88
Sep 18, 2017 01:34 PM
MonteroMan
Dec 1, 2014 07:29 PM
DiscoRover007
Jul 12, 2012 09:28 PM
