Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Rover classic 1993 belt replacment -- help?
Old Aug 2, 2023 | 11:14 AM
jfhunting's Avatar
3rd Gear
Default Rover classic 1993 belt replacment -- help?
I need to replace the belts on my Rover 1993 classic. As far as I can see, the fan has to come off to do this. I appears that there are tensioner pulleys on some of the belts. I couldn't find much info in the RAVE or anywhere else on line. Any advice on this job (or links) and special tools needed would be greatly appreciated. thanks....
Old Aug 5, 2023 | 05:53 PM
swissarmychainsaw's Avatar
I don't know the answer here, you should be able to 'weave' the belts between the blades of the fan and get them off/on.
If you can't do that here is how you remove the fan:
Old Aug 5, 2023 | 08:06 PM
jfhunting's Avatar
3rd Gear
thanks...
Old Aug 6, 2023 | 09:57 AM
jfhunting's Avatar
3rd Gear
do you have any idea if the betls have tensioner pulleys or each one has to be manually adjusted? I see pulleys, but they dont have any socket fittings to move them?
motorheadny
Jul 24, 2014 08:50 AM
kenrickgsxr
May 1, 2014 08:58 AM
GLW52
Jan 6, 2014 09:56 AM
discolvr71
Jan 21, 2012 11:43 AM
KeizerRover
May 9, 2008 05:05 PM
