Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
2012 Evoque 2.0 Engine swap
Old Aug 3, 2020 | 08:28 AM
wbender4's Avatar
Default 2012 Evoque 2.0 Engine swap
Hey all,
I am new here and have acquired a 2012 Evoque with a bad engine (knock on cylinder 4). It has the 2.0 turbo that I believe is the ford eco-boost engine. Do I need to buy an Evoque engine or will a w.o eco boost out of a 2011-2014 edge/escape/explorer work? I have searched all over and cannot find if there are any internal differences. I will swap over all the Evoque accessories and sensors and install a new turbo/manifold while I am at it. Thanks!
Old Oct 3, 2021 | 05:00 PM
Rav's Avatar
Rav
Originally Posted by wbender4
Hey all,
We can work it out together if you wish!!
hey buddy, have you got that fixed with Ford Escape engine. Let me know please if we can swap evoque engine with Ford engine. Is there any issues with fitting or assembly?? Thanks
Old Mar 20, 2022 | 07:15 PM
wbender4's Avatar
All, I have successfully swapped the engine with an edge 2.0 ford motor and am doing my second swap with a escape 2.0 ford motor
Old Mar 20, 2022 | 08:00 PM
will@europartsandoverland.com's Avatar
that is awesome, fantastic job. You should post up about how to go about it I am sure there are others that would love to know how to do it
Old Apr 4, 2022 | 01:02 AM
Hav0k's Avatar
3rd Gear
I just did a swap on our 2012 evoque using an engine from a 2013 ford escape. It wasn't too bad.
The following have to swapped over from the evoque engine to the Ford engine:
Oil pan
Timing cover
valve cover
all brackets/mounts
Things to be aware of:
The harmonic balancer has to be removed and swapped over but it doesn't have a keyway and requires a special tool kit to line back up properly. You could likely lock each engines crank in place with a home made crank pin from the kit and just mark the balancer and sensor locations and then just line them back up, I learned this after swapping the balancer
The turbo system is different. You will have to get a new turbo v-band with weld on flanges and make a custom adapter or get the downpipe from the ford and join it to the evoque exhaust
JEL
Feb 25, 2018 08:10 PM
reporob
Mar 2, 2014 03:00 PM
JumPeR04
Oct 2, 2012 07:25 AM
SDinDS
Jan 19, 2010 09:52 AM
03discoman
Dec 18, 2009 09:29 PM
