Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
Air conditioner problem.
Old Jul 27, 2024 | 04:58 PM
Ozarks's Avatar
4th Gear
Default Air conditioner problem.
My wife's 2015 evoque is having intermittent air conditioner problems. On short trips of 50 miles no problem but longer trips it sometimes happens.
it will work fine and then stop blowing air from the vents. Shut it down for a while and it will work again.
I can hear the fan running strong but nothing out of the vents.
Is this a freezing problem? What do I need to do to fix this problem?
Thanks for any help.
Old Jul 31, 2024 | 02:19 PM
gmfain's Avatar
Sounds like blend door actuator.
Are there any codes?
Old Jul 31, 2024 | 02:30 PM
Ozarks's Avatar
4th Gear
The only thing we have found that works to get it going again is shutting the car or air conditioner off for a while. Would the blend door have anything to do with that?
Haven't checked for new codes. Check engine light is on and we had it in the shop and spent quite a bit of money only to be told they couldn't get it off.
Old Aug 1, 2024 | 09:28 AM
gmfain's Avatar
There is more than likely a module that controls it.??
You will need a Scanner that reads Land Rover codes.
Do you have an Indy Shop? ( independent land rover shop)
fyi, most regular readers don't see all Land Rover codes, and can't clear them.
I bought the Launch CRP 909, which now is the crp919 I believe.
Amazon Amazon
Old Aug 1, 2024 | 05:19 PM
Ozarks's Avatar
4th Gear
There's one about 100 miles away.
Really hot today and made a 60 mile round trip and no problems. Just on longer trips it seems to arise.
Old Aug 1, 2024 | 05:40 PM
gmfain's Avatar
check your battery age first.
I know, Auto zone says its good, if it older than 3 years, change it.
Old Aug 1, 2024 | 06:09 PM
Ozarks's Avatar
4th Gear
I'm leavng in a couple days for several months so it will have to wait until I get back. I appreciate your help.
Ianmark
Range Rover Evoque
Nov 30, 2023 03:14 PM
Nopig
LR2
Jun 26, 2019 10:06 PM
slexum
Dec 27, 2008 07:03 PM
chieftke
May 8, 2007 06:55 PM
4x4freak
Apr 11, 2007 09:48 PM
