Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2006 - L322 - Steering Column Issue/Key Not Turning Issue
Old Oct 21, 2021 | 06:53 PM
TverTrekker's Avatar
4th Gear
Default 2006 - L322 - Steering Column Issue/Key Not Turning Issue
Howdy Fellow Landies,
So I have now been plagued with the infamous Range Rover HSE L322 - Steering Column Issue/Key Not Turning Issue. I know it is a common issue and know there are lots of fixes but to no avail, none have worked.
Unfortunately, I have tried:
1. The "Terminal off battery Battery"
2. The Pull the "Fuse 18"
3. Top of "the steering column pull the column tab & spray WD-40"
4. The "precision" rubber mallet whack
and it did nothing. None of the "fixes" above did anything to get the steering column unlocked or recognize the key, or do the notorious double click like it should when the key is near the column. I'm truly at wit's end as I do not know what else to do? I am assuming it's a new/used steering column with a new/used immobiliser? Not sure what else it would be? Any suggestions would be really appreciated! Thanks in advance for any advice.
All the Best
TverTrekker "Immobilized in Texas"
ROMELLO
Oct 19, 2021 04:42 PM
nwr1967
May 10, 2021 08:16 PM
cheeky9191
Apr 20, 2013 03:51 PM
johnatjrnorth
May 19, 2011 12:57 AM
luvmyrover1074
Dec 4, 2010 09:02 AM
