Newbie Questions....
Old Oct 13, 2018 | 09:59 AM
Groucho123's Avatar
Default Newbie Questions....
Does anyone know if when you put the tranny in sport mode...if it changes the suspension to being a harder ride?
Also....
If you have the suspension on the high ride height does it also change the suspension? How about the lowest setting?
Thanks in advance!
Old Oct 13, 2018 | 10:03 AM
abran's Avatar
Access height gives you a bouncy sloppy ride(less air in bags), off road gives you a tighter stiffer ride(more air in bags).
Not sure if sport changes the suspension settings.
I just got a GAP tool for our D5, probably going to adjust the normal ride height to be a little higher.
Old Oct 15, 2018 | 08:35 PM
ponderosajack's Avatar
what's a GAP tool and where'd you get it?
Old Oct 15, 2018 | 08:52 PM
abran's Avatar
Lucky8 has the best price. $500 ish
its the most powerful diagnostic tool you can buy for under $10k.
Old Oct 15, 2018 | 09:08 PM
Groucho123's Avatar
Default Ok..
What does it do?
Old Oct 16, 2018 | 12:29 AM
abran's Avatar
You can adjust your ride height, make custom ride height settings for Offroad, read and clear all codes.
on the more advanced sides you can update software, etc.
i have not had time, but going to see if I can reset service monitor.
Old Oct 16, 2018 | 06:49 PM
preeble's Avatar
my car does not stay in low ride height and I believe that is by design. Does yours stay low when driving at faster speeds? I think that the low/high ride heights are only to be used for specific circumstances.
Old Oct 16, 2018 | 10:52 PM
abran's Avatar
The standard height is what your car will stay in while driving.
With GAP if you add 1” to normal ride height, access and offroad height will be 1” taller.
rsvrman
Nov 23, 2022 09:12 PM
Nj2019
Dec 24, 2018 05:22 PM
squish
Dec 12, 2017 02:37 PM
zoltan7
Apr 12, 2017 08:32 AM
realtor1
Jun 9, 2016 11:43 AM
