Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2008 Range Rover HSE Code P0741
Old Feb 18, 2021 | 06:07 PM
mbrovi's Avatar
Default 2008 Range Rover HSE Code P0741
I need some expert help before I do anything. So I have inherited this truck from someone who I can no longer get a hold of. I didn’t buy it, i was asked if I wanted and I said of course knowing there will be some surprises. The truck has been parked for who knows how long so I got a new key made and charged up the battery and once I got in and started the engine there it was the surprise of all surprises. Check engine light, parking brake and brake lights are all on. I let it run for awhile then put a scan reader on it and got this codes
P0730 Incorrect gear ratio
P0735 Gear 5 incorrect ratio
P0736 Reverse incorrect ratio
P0741 Torque converter clutch solenoid- circuit performance or stuck off
P0783 3-4 shift
U0155 communication with instrument cluster control module
The truck shifts gears and moves in Reverse but when in Drive, it doesn’t move at all. I forgot to mention also that I discovered 6 qts of Pentosin trans fluid with transmission filter kit. My question to you experts is should I start with having the trans serviced and check the valve body components before considering a replacement??
mds
Jan 5, 2021 06:20 PM
gsd2004
Jan 6, 2019 12:46 PM
RANDY04D2
Aug 19, 2014 08:48 AM
kimani01
17
Mar 1, 2012 07:35 AM
