Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2008 Supercharged Engine/Transmission leak questions
Old Mar 6, 2022 | 11:10 AM
Jamezbond27's Avatar
Default 2008 Supercharged Engine/Transmission leak questions
Hi,
I have at least three leaks on our 2008 Range Rover Supercharged.
It looks like a sensor on the right valve cover is seeping. Can someone please confirm which sensor is seeping in the photo?
Also, I think the transmission collar is leaking as well. Is this the leak near the electrical connection or could something else cause this?
Also, it looks like there's a seep near a bolt around the left valve cover area? (I think)
Any advice would be recommended. Anything else to check for around these areas?
Thank You very much!
Old Mar 6, 2022 | 07:51 PM
I believe the leak on the right valve cover is the vvt solenoid seal. Does this sound right?
What is a reasonable charge to replace the transmission fluid/pan/filter/valve body sleeve? Dealer vs independent cost?
I really have zero idea what is causing the third leak.
Thank You
DISCOFETA
Jan 9, 2022 11:00 AM
LR2driver
LR2
Dec 28, 2021 09:40 AM
rdlevy1215
May 29, 2020 07:08 PM
CandiMan
May 20, 2011 10:50 PM
aTX427
Mar 3, 2010 08:59 AM
