Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2010 L322 Key Not Working
Old Jun 10, 2021 | 07:01 PM
sammywammy53b's Avatar
Default 2010 L322 Key Not Working
I had some issues with "Smart Key Not Found" and poor ket fob reception (only locking and locking when very close to the car) so I assumed the battery was getting low.
Whilst in the supermarket I saw the battery for the key fob so bought a new one. I changed the battery and now the key won't work.
None of the buttons responded with the car, so I had to open it manually. The alarm went off and so I tried to place the key under the steering column to be detected and start the car, but this didn't work.
The key just stopped working.
Any tips on why this might be, or how I can fix it?
Old Jun 24, 2021 | 05:15 AM
Bigbroadjumper's Avatar
3rd Gear
I have had this issue as well. What I have found that works is to remove the fuse, I believe it's #17 a 5 amp fuse for at least a minute. Also disconnect the park assist module located in the rear compartment on the drivers side (left hand drive). There are three connectors. Once I put the fuse back in, my car is back to normal operation for a few weeks or months is some cases. Not sure if mine is a park assist issue but that seems to work for me.
Also once the car starts I reconnect all three connectors to the park assist module.
Good luck
Rutrover
Aug 24, 2019 06:23 PM
jeffh
LR4
Feb 14, 2019 07:57 PM
dtm325
Nov 1, 2013 11:50 AM
Jo1175
Dec 9, 2011 06:56 PM
miranda52
Dec 22, 2008 03:47 AM
