Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2011 TDV8 4.4 Amber DPF warning not showing despite 23g showing on IID Tool
Old Apr 4, 2022 | 05:40 AM
Solway Bob's Avatar
Default 2011 TDV8 4.4 Amber DPF warning not showing despite 23g showing on IID Tool
Hello everyone, first post on this site so a quick introduction is only fair I guess. I'm a long term Range Rover owner having had a number of Classics (3.5 and 3.9), moved to a P38 then a Discovery 2 a Freelander 2 (which I still have) and now a 2011 L322. I've had never ending DPF issues which are now almost sorted, new N/S inlet manifold, Plenum and hoses have stopped the fill rate going up at an alarming rate and is more in keeping with how it should be. The issue I have is that when it comes to the vehicle trying to carry out a regen, the process starts but the temperatures on the exhaust sensors are incorrect. Instead of getting up to 600c on sensor 2 I get around 450c, however, sensor 3 reads at 600+c. After a lot of research it would seem that these figures should be the other way round, sensor 2 being at the start of the DPF where the heat needs to be to burn off the soot. The temperatures are only maintained for around 5 minutes when they drop down to around the 350c mark. I have tried setting cruise to 55MPH on a quiet motorway but instead of the soot level going down, in goes up (albeit slowly). If I leave the motorway and come back via an A road with traffic lights and roundabouts, the soot level drops by 2 or 3 grams each time I come to a stop. Because of all the hassle I've monitored the soot level each time I've been out, today it stands at just below 23 grams and I should have an amber warning light but none is showing. I should mention that the DPF has been removed and cleaned and the vehicle has been told it's got a new DPF using the diagnostic tool and all is fine until obviously it fills up again. On one or two occasions I've had a plume of smoke billow out of the exhaust which I assume is unburnt diesel?
Any body have any ideas or have heard of anything similar before?
nengelbrecht6
Jul 28, 2023 05:39 PM
DakotaTravler
Sep 8, 2021 07:35 PM
AdrenalinPlease
Jun 13, 2018 02:18 PM
spannermonkey
Sep 24, 2017 07:58 AM
Niver39
Oct 29, 2015 03:35 PM
