Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Coparts purchase!! 2012 RR SC.
Old Apr 26, 2020 | 04:08 PM
jagmorony219's Avatar
8th Gear
Default Coparts purchase!! 2012 RR SC.
Hi guys,
Recently purchased "mechanical" issue 2012 RR SC with 70k on the clock. Car fax clean other than small fender bender 2 years ago.
I got the car it won't start. Replaced batter checked all ecus with IId tool. No faults besides instrument cluster.
Car has a slight click when trying to crank but doesn't physically crank but I hear the starter relay and whine slightly.
Changed the oil and a gallon of gas came out. Changed oil still won't crank.
​​​​​ Any advice would be great as I'm out of ideas. Even with a stick injector it should still crack
hit the starter with a hammer while cranking still nothing
Let me know what u guys think
Thanks
Phil
Old Apr 26, 2020 | 04:14 PM
Is the engine seized? Have you verified the starter is good?
Old Apr 27, 2020 | 05:32 AM
8th Gear
not entirely sure how to manually crank without taking apart fan etc. I bought a refurbished starter. Will install when it arrives, as I was getting some weird voltage drops. any other way to see if seized without ripping things apart?
no metal in the oil/gas so that is good.
Old Jun 4, 2020 | 11:17 AM
beebe's Avatar
Mine had a blown 400a fuse in a plastic case that hangs down from the positive battery terminal.
Old Oct 10, 2020 | 06:06 AM
Kevmart73's Avatar
The only only way to check to see if it’s seized or not is turn over the crank. Turn it clockwise. Do not turn it counterclockwise. I doubt it’s seized. Most of 5.0s are mechanically totaled due to timing chain issues. I’d borescope the heads. See if they’ve banged against the valves. You can get a borescope camera for $10 plugs into an iPhone.
Manbeer
Jul 2, 2017 10:35 PM
jerrodp1
Dec 15, 2014 05:50 PM
sydskier006
Apr 18, 2007 07:33 PM
