Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
L322 Aftermarket Towing Ball Mount
Old Dec 28, 2020 | 02:37 PM
lschwarcz's Avatar
Default L322 Aftermarket Towing Ball Mount
If you want to tow with your L322 you’ll need to get the wiring harness, ball mount and ball for the trailer hitch. I believe all L322’s came with the hitch installed.
The OEM ball mount kit is rather expensive and you may not need to spend that much.
Land Rover Drawbar Kit LRK20941 - $300 (roughly)
The OEM ball mount has an 11” length and 3-½” drop. I found a Curt ball mount that’s so close that it may as well be the same. The Curt mount has an 11-1/8” length and 4” drop.
Curt Dual Length C45230
https://www.curtmfg.com/part/45230
If you want the fancy OEM ball with the interchangeable ***** it’s made by Reese Towpower 74309.
https://www.reesetowpower.com/produc...ler-hitch-ball
If you don’t need to have the interchangeable sized ***** you can just buy the size you need. Personally, I wanted the dark grey color that I thought would better match the car.
I bought the Reese Towpower 7060400 Class IV ball with the Black Nickle finish.
I also wanted a locking pin since I leave the ball mount on the car. I like the Softride Quiet Ride Locking Tightening Hitch Pin (25219).
https://softride.com/product/quietri...ing-hitch-pin/
Costs:
  • Ball Mount - $30
  • Ball - $15
  • Locking Pin - $40
TOTAL: $85
If you want the interchangeable ball like in the OEM set it’s about $40 from Amazon.
All prices are subject to change of course. These are approximate prices as of Dec 2020.
Have fun!
Larry.
Old Feb 10, 2021 | 05:02 PM
AndyRoverHSE's Avatar
5th Gear
Very helpful info, thanks. I too just picked up an aftermarket set up for some quick U-Hauling. Used same for an old Trooper.
merebel
Oct 29, 2020 09:42 PM
Snowlion
Oct 29, 2020 01:56 PM
cvhyatt
Jan 23, 2020 05:41 PM
green_
Jul 17, 2010 08:25 PM
jtherien53
Jun 5, 2010 08:20 AM
