Lifting points on L322
Guys, just bought a 2004 L322, got it for a good price due to the engine not running. Timing chain broke or jumped time with prior owner. Anyway, I’ve got it in my shop and being new to the Land Rovers, I’m wondering where are the recommended lift points. The air bags are all deflated as well, so not super easy to see underneath- front looks like I could lift on the frame near the lower control arm rear connection points. Rear, covered in plastic underneath- can I lift on the round can like structures just inbound of the front of the rear tires? I have an asymmetrical lift (Rotary Brand, 10k lb) and several options for the lifting pads on it’s arms. Let me know guys, ready to get after this motor, but I don’t want to goof things up lifting it!
Also, is there a “access mode” for the suspension I need to go into before lifting? I know newer models have this.
thanks guys, Clay
thanks guys, Clay
take care, Clay
Okay got it lifted. Used the connection between the front sub-frame and main frame up front. Very stable there. For the rear, I just went for it on the little squares and they pushed up slightly but seem to be good.
On another note, Trans pan is covered in oil - very dirty so hard to tell if it’s trans oil or engine oil. Active leak somewhere.
Tons of questions after looking at the engine from underneath. The front drive axles go right through what I think is the oil pan (upper). So for the timing chain repair, what a mess to get this off! My understanding is that the M62 tú has a few bolts for the timing cover inside the oil pan - so this has to come off.
I’m wondering now if this would all be easier to bite the bullet and drop the entire front sub-frame - Engine trans and all. Out from under the Rover, then do everything from there???
You guys know of any videos on this? Gonna look myself. Boy, no wonder no one wants to fix these...
