Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Towing with an L322?
Old Jan 10, 2020 | 12:07 PM
DavidG993s's Avatar
5th Gear
Default Towing with an L322?
Is anyone towing with their L322? If so, what kind of weight are you towing and what's your experience with the L322 in a towing scenario?
Cheers.
Old Jan 10, 2020 | 08:55 PM
John Monroe Zimmerman's Avatar
I tow my boat, my utility trailer, my kayak trailer. With my boat, the boat, trailer, gear, is around 5500ish pounds. Tows fine. Not sure what you're asking? It's a full size V8 SUV. It can tow over 7500 pounds. What do you want to tow?
Old Jan 29, 2020 | 07:21 PM
DavidG993s's Avatar
5th Gear
Does anyone else have any input regarding towing with an L322? There's certainly more to towing capability than "it's a full size V8 SUV". The 4.4 is a nice V8 but it's not terribly powerful. Are the brakes up to the task, and at what towing weight? Is the transmission capable of towing 5-6000 lbs. as I don't think it has a trans cooler (correct me if I'm wrong). I'm considering using it to tow an open trailer and car totaling around 5000 lbs. I know it's rated for 7700 lbs., but it's never advisable to tow the maximum capacity. I've towed with a Chevy Suburban in the past, but never with a Range Rover.
Any additional input would be appreciated, especially the weight you're towing and your experience/advice.
Thanks.
Old Jan 29, 2020 | 07:35 PM
Yes it has a transmission cooler, and more than enough to pull what you’ve posted. And for the comment about not being advisable about pulling max towing weight, you’re definitely wrong there. That’s the maximum recommendation by manufacturer typically minus trailer brakes. With a proper set up you can easily pull more. Seriously, you’re not going to hurt the car pulling that far under. I pulled more than you’re wanting to pull with my old X5 and that was rated to 6k pounds. If you’re that afraid of the RR, and don’t even know that it has a trans cooker, then maybe you really are better off in that Suburban.
LADEROUTE
Apr 30, 2024 08:43 AM
SuzSS
Nov 29, 2019 07:17 PM
LR03NJ
Aug 13, 2014 03:20 PM
oljohnboy
Nov 29, 2010 04:14 PM
DNTL911
Nov 29, 2005 11:19 PM
