Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
GPS color of the OEM cable L405
Old Sep 17, 2021 | 01:55 PM
luigihdez's Avatar
Default GPS color of the OEM cable L405
Hi! I am installing a new screen, and I want to use the factory antenna for the GPS, but I have a question, that cable is? What color? I have green, a light pink, a dark pink and a brown cable, I don’t know what cable is, I would appreciate your help
Old Dec 27, 2021 | 06:45 AM
JAAChard's Avatar
i have the same question as I bought a GPS splitter cable to be able to use the cars GPS rather than installing the separate GPS supplied with the Merryway unit.
however like you I have come unstuck as there isn’t a blue connecter to hijack.
does anyone know if it is the green, pink, brown or purple connector? I assume it has to be one of them.
Old Dec 28, 2021 | 05:53 AM
JAAChard's Avatar
I found the cars GPS connector - it is located on th back of the DVD/Bluetooth unit. You have t remove this to fit an aftermarket android screen anyway.
I have dispensed with the ‘weak’ (IMHO) GPS unit provided with the Merryway head unit and made use of a GPS splitter cable. Strong GPS signal now obtained.
Ow does anyone know how to tap into the cars GSM cable (via a splitter cable) so that I can get rid of the little GSM aerial provided with the android unit?
Got to love a splitter cable as you need less aftermarket cables chased around the car!
dsperling2
Nov 8, 2021 08:27 PM
nigelryoung
Mar 17, 2016 12:13 PM
toofaroffroad
Dec 30, 2012 11:51 AM
ColoDisco
Jul 26, 2011 06:28 PM
michaelfisk
Jan 11, 2011 08:59 AM
