Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Rear passenger AC roof vent not blowing
Old Jun 29, 2024 | 10:46 PM
TheGrand's Avatar
Default Rear passenger AC roof vent not blowing
Hello, when changing air to roof vent, all air blows out driver side roof, passenger side makes a little noise but no air. Not sure where the blend doors are for rear AC. Thanks
Old Sep 13, 2024 | 12:31 PM
scottdmd03's Avatar
3rd Gear
Hello! I am having the same issue with my 2019 Sport. There is no air blowing out passenger rear roof vent.
I hope you were able to resolve the issue. If so, would you mind sharing the fix? Thank you
Old May 26, 2025 | 06:40 PM
Hammer17's Avatar
Default Rear Ceiling AC vent not blowing - solved
I pulled out the rear passenger ceiling vent by pressing the the small tab inside the vent. Pull down and towards the front of car to pull out. Once out, I noticed the door that swings open and close in there was stuck closed. This is why no air would come our. There is a little swing arm connected to the door that popped out and needed to be reseated. Fairly simple fix. I put a little grease in there so the door would swing open and closed easier. Vent snaps back in pretty easily and all working well now. That little swing arm can pop out again if you spin the wheel all the way until it locks in both directions. I found if I spin the wheel just until before it gets to the end/lock positions, there was no issue. If I fully spin the wheel either open or closed to the lock positions it would occasionally pop out again. See pics for little tab to pry open with small screwdriver and then pull out with needle nose pliers.
Old May 26, 2025 | 09:19 PM
scottdmd03's Avatar
3rd Gear
Thank you! I will try it soon and report back. Dealer wanted $2k just to diagnose it!
Old May 27, 2025 | 07:49 PM
scottdmd03's Avatar
3rd Gear
Thank you, thank you thank you! One caveat is that I needed to remove the vent cover using standard interior component wedges. Once I got the vent cover off, I was able to remove the interior compartment that you showed in the photos. The articulating arm seems rather complex and it disengaged from the small baffle/vent control, just like you said. Unreal that the dealer want to charge me two grand just to diagnosis! Thank you so much for your assistance.
Old May 28, 2025 | 09:40 AM
wcc18999's Avatar
Glad you got it resolved.
Old Jun 10, 2025 | 04:56 PM
TheGrand's Avatar
Worked great, thx
DryFly Trout
May 17, 2024 08:57 AM
gclasse
Mar 30, 2019 12:24 AM
machinetech
Aug 2, 2016 07:31 PM
wynhd
Sep 22, 2015 11:20 AM
jsyonker
Nov 1, 2007 07:22 PM
