Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
suspension 2016 hse
Old Dec 27, 2021 | 07:54 PM
vogelbaugh's Avatar
8th Gear
Default suspension 2016 hse
Hi, i am on my second Land Rover, this one a Range Rover HSE, i am getting the message "suspension will raise when system is cooled". Car is not on the bumper stops, but gets really wishy washy when that message pops up. I have seen things that say to do a rebuild on the compressor, but im not sure which kit to order... let me know if you have had success doing this, not having the best luck with this car. I have already replaced the leaky coolant hose/pipe under the turbo charger on the front of the engine on this car, and i have a suspicious coolant leak that is starting from the back of the engine.. just taking things one at a time.
Old Dec 28, 2021 | 09:26 AM
Perfectphoto's Avatar
What engine do you have and how many miles?
Old Dec 28, 2021 | 12:21 PM
vogelbaugh's Avatar
8th Gear
2016 Land Rover Range Rover HSE 6 Cylinders 3.0L FI SC DOHC 183 CID, 77,000 miles
my other rover was a 2006 range rover sport, after ten years in arizona all of the plastic pieces in the engine crumbled away, this included the water pump housing etc.
Old Dec 28, 2021 | 12:41 PM
I have that about the 3.0s and the 5.0s I think I will stick with my TD6
Old Dec 29, 2021 | 05:28 PM
vogelbaugh's Avatar
8th Gear
i maybe just noticed that the front passenger is sitting a little lower, so maybe i have a leaky boot. but i just wanted to see if anyone had done the rebuild on the suspension compressor. I'm pretty sure the rebuild is just the O-rings and hoses right at the pump.
Aaron Hunter
Mar 7, 2021 11:01 PM
Boxerdaddy
Feb 22, 2020 09:24 AM
petergeraerdts
Feb 14, 2016 05:22 AM
mixomax
Sep 24, 2009 12:54 PM
BD997
Jan 22, 2007 07:46 PM
