suspension 2016 hse
Hi, i am on my second Land Rover, this one a Range Rover HSE, i am getting the message "suspension will raise when system is cooled". Car is not on the bumper stops, but gets really wishy washy when that message pops up. I have seen things that say to do a rebuild on the compressor, but im not sure which kit to order... let me know if you have had success doing this, not having the best luck with this car. I have already replaced the leaky coolant hose/pipe under the turbo charger on the front of the engine on this car, and i have a suspicious coolant leak that is starting from the back of the engine.. just taking things one at a time.
2016 Land Rover Range Rover HSE 6 Cylinders 3.0L FI SC DOHC 183 CID, 77,000 miles
my other rover was a 2006 range rover sport, after ten years in arizona all of the plastic pieces in the engine crumbled away, this included the water pump housing etc.
i maybe just noticed that the front passenger is sitting a little lower, so maybe i have a leaky boot. but i just wanted to see if anyone had done the rebuild on the suspension compressor. I'm pretty sure the rebuild is just the O-rings and hoses right at the pump.
BD997
Jan 22, 2007 07:46 PM
