Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Wheel speed sensor codes.
Old Oct 6, 2025 | 03:56 PM
RescueDog1's Avatar
Default Wheel speed sensor codes.
left rear code for an ABS wheel speed sensor. Replaced the sensor with genuine Bosch part cleared the codes but now this pops up. P0501-86 (2F). Vehicle speed sensor A range performance. Bus Signal message failure. Im disconnecting the neg battery terminal and hoping that helps. Using GAP 2 tool. The other codes are cleared.
Old Oct 6, 2025 | 06:18 PM
wcc18999's Avatar
Did this message appear after changing your brake pads or did it just appear randomly?
Old Oct 7, 2025 | 12:31 AM
RescueDog1's Avatar
Randomly. Just driving along and Christmas tree lights and lowered itself.. Had this happen on my LR3 with the ABS wheel speed sensor and the new sensor cleared all the codes. This one is deeper than what i can do with the Gap Tool. It may be a sticking caliper, I don’t know.
Old Oct 7, 2025 | 05:29 AM
wcc18999's Avatar
Have you checked the battery and the ground? If your battery is weak, it can throw out all kinds of codes. Same if the ground is loose or corroded. If your battery is old, time to replace it.
Bhalbach
Apr 26, 2025 09:25 AM
PilotHobs
May 6, 2023 03:43 AM
CanadianRover
Jan 20, 2020 07:21 PM
MuleyJ
Sep 28, 2016 11:47 AM
twaszak
Jun 4, 2011 07:49 AM
