Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Another P38 ABS/BRAKE issue
Old Oct 11, 2021 | 03:34 PM
ThatcherP38's Avatar
5th Gear
Default Another P38 ABS/BRAKE issue
So I know a lot has been written on the ABS issues with the Range Rover p38 and I have read everything I can find and am still stumped. 2002 Range Rover P38 LHDHere is a list of my symptoms and everything I have tried... Car running great, no brake issues, occasionally abs brake and TC lights would flash on and off when first pulling away then didn't come on. Put it in garage to do some cleaning and check code which was for maf sensor. Removed it, sprayed with electronic cleaner and replaced, also sprayed plug connectors. After a while doing some cleaning of the rest of the inside, I started it up and immediately had ABS, brake and TC lights on and soft pedal, no braking power, but would build some pressure back with multiple pumps of the pedal but braking quality still poor. Checked codes and no more maf sensor code but got p01592. Not much other history because I purchased the car a week before this. So I began diagnosis... Checked and rechecked all fuses and relays, no issues. ABS relay tested and has continuity when energized.Brake pump will not turn on unless I jump the relay, then braking power returns but ABS and TC lights remain on. Replaced accumulator with new one, no change.Replaced entire brake pump unit with used, no change.Tried to test/ground pressure switch with no results. Tried to ground the black/yellow wire in pressure switch and pump did not come on on either unit.Cannot seem to get power to the plug for pressure switch. I've tested each pin and nothing. Not sure if there is supposed to be power but seems likely.Have continuity on pressure switch (both) Replaced ABS ECU with a used on, no change. My conclusion is that the relay is not getting the signal to turn the pressure switch on but I cannot figure out why. And my test of the pressure switch and plug are inconclusive in my opinion. Could a faulty wheel sensor cause all this? I didn't think that it would cause the brake pump to not come on but I'm not sure. Sorry for the long explanation but wanted to put as much information as possible. Hopefully someone has some ideas or other ways of improving my diagnosis techniques.
Old Oct 14, 2021 | 09:53 PM
5th Gear
Default Update to ABS ISSUE
Update:No luck so far. Found another used pressure switch no change.I did put power directly to the black/yellow wire in the plug and it energized the relay and pump turned on.It would not turn the pump on if I put power to the black/yellow wire (from the back if the plug) if it was plugged in to the switch.There is continuity between B/Y, B/W, and one of the ground wires. Not sure if this is correct or not.There is also continuity among all wires from the pressure switch plug to the corresponding wires in the ABS ECU plug (middle black one) I can't figure out where the fault is. Anyone have any thoughts? I've tried another used ABS ECU, from an older P38 and no difference. Please help!!!!!
Roflcopter
Jul 19, 2016 11:07 AM
TOM R
Feb 24, 2014 07:35 PM
wastedincome
Oct 16, 2012 01:21 PM
lordmorpheus
Apr 17, 2012 01:41 PM
allensp38
Dec 31, 2009 12:15 PM
