Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
HEVAC issues
Old Nov 4, 2021 | 02:37 PM
ThatcherP38's Avatar
5th Gear
Default HEVAC issues
Still working on the 2002 P38. I have previously posted and fixed the ABS issue with a new (used) fuse box replacement, all is good there. I have replaced the broken heater core using the short cut method.My issue is with the hevac control unit. Mine did nothing basically and did not light up but the seat heaters and windscreen heaters work.I replaced the unit with a used one which works nicely but I lost the seat heaters and windscreen heaters. So I put the old one back in and both things would not work and the light would not come on above the buttons. I checked fuses and relays and still nothing. Any ideas? Maybe the wiring came loose at the pins?
cammyr01
Feb 5, 2016 05:58 PM
AK Rover
Aug 24, 2008 05:57 PM
starcraft
Nov 13, 2007 04:14 PM
95DiscoSE7bullitt
Mar 4, 2007 01:57 PM
