Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Maxi 50 amp Spare
Old Apr 15, 2021 | 02:32 PM
Gallanjc's Avatar
7th Gear
Question Maxi 50 amp Spare
Has anyone had this issue, my 50am maxi fuse blew, mmmm, so , not sure what it is running, the manual says its a spare?? Spare to what? I don't have any other 50 amp maxi fuses, the rest are 60 with one 40, Truck runs fine?
Any thoughts,?
I am having problems diagnosing my SAI, thought it might be related, but cleared the code , changed the fuse, after a day the SAI came up again but fuse is not blown??
Cheers,
Thank you,
Old Apr 15, 2021 | 02:47 PM
Harvlr's Avatar
How do you know it blew and it wasn’t a PO who put their blown fuse in the spare space? Yours must be Bosch (as you have SAI). Mine is GEMS, so I won’t be much help.
Old Apr 15, 2021 | 03:17 PM
Gallanjc's Avatar
7th Gear
Its a new box, I put it in myself about two years ago, all the fuses were new, so , yes I can confirm I have done a fuse check more than once over the last couple years, however, I cant remember 100 % if I checked the Maxi fuses , Think I did ? but that still would not answer the other question, the manual says its a 50 amp spare but there are no other 50 amps, so ???
greisinb
Nov 25, 2019 04:00 PM
redrover75
Jan 7, 2017 07:17 AM
tofargone
Oct 13, 2014 10:42 PM
southen96disco
Dec 7, 2012 09:49 PM
cbh
May 27, 2010 07:49 PM
