Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
P38 fuse box differences?
Old Feb 22, 2021 | 11:45 AM
Jason Wheary's Avatar
Default P38 fuse box differences?
I actually signed up for my friend who has a 1998 p38 4.6 HSE. His main cable lug on the fuse box from the battery to the fuse box was loose. I was searching and found out there are two fuse boxes that are almost identical. An ARM6405, and an ARM6476. What’s the difference in these two boxes? And are they interchangeable?
Old Feb 22, 2021 | 12:00 PM
Paul Smith's Avatar
Hi mate. It's actually a good question. Try to use an OBD2 scanner. I connected and ran the diagnostic on my Range Rover. It's a very useful tool.
Old Feb 22, 2021 | 12:02 PM
I know it’s the fuse box. The lug was loose on the board. I am just trying to see if those two boxes I listed are interchangeable or what’s the difference in the two?
Old Feb 22, 2021 | 01:13 PM
keninnc's Avatar
No not interchangeable. I forgot the difference but I have a 2001 P38 and a couple of years ago I changed out the fuze box. I ordered the incorrect one and it was not able to hook up and therefore would not work. I had to send it back and get the correct one.
Old Feb 22, 2021 | 02:39 PM
Harvlr's Avatar
I’m pretty sure the difference is GEMS or Bosch. If you check the part numbers on LRCat they generally list the P/N up to a VIN of from a VIN #.
greisinb
Apr 6, 2020 05:07 AM
CameraDan
Sep 12, 2019 11:52 AM
drowssap
Oct 20, 2015 10:23 PM
iambhooper
Feb 20, 2014 07:17 PM
nickm347
Jan 10, 2011 09:28 AM
