Charging system fault Range Rover sport supercharged
Good day
I have a Range Rover sport 5 litre supercharged 2011 model I used sport mode at night and it stopped charging the battery cause the battery sign came on and the message it stated for 2 days then a technician came and took the car ,plugged it on a machine and he said the battery was weak but the alternator is charging so I drove home and no hustle at all then I bought a new battery after a week and drove in sport mode again it started the problem I’ve since parked it what might be the issue here cause now it keeps saying charging system fault
Charge fault light stays on although no issues...help
Did you ever get a fix, I have the charging fault light on as well and despite everything between the engine computer and the alternator being brand new it still says charging fault although the car is running perfectly. It is a 2010 supercharged sport. Any info you may be able to share would be greatly appreciated,
cheers.
cheers.
Moses7
03-24-2014 11:43 AM
