Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Click/Squeak on rear wheel hub/CV???
Old Jan 8, 2022 | 07:47 PM
DBLDisco's Avatar
Default Click/Squeak on rear wheel hub/CV???
Hey guys, so I recently replaced ebrakes /rotor /brakepads on my 2008 RR Sport Hse, no issues with the job everything was replaced set and calibrated, epads bedded with no issues... however when driving I began to hear a spring sounding click or squeak that sounded as if the hub was possibly rubbing against one of the epad springs... so I jack up pull caliper, brakes and rotor off and then while turning by hand try to find the source of the squeak. narrowed down that hub wasnt rubbing and the squeak appears to be behind the hub possibly inside the cv boot?? has anyone had or identified this specific issue? ....remove ones and follow links for video showing issue.. Any feedback would be much appreciated....thanks
Old Jan 10, 2022 | 07:08 AM
DBLDisco's Avatar
Bump up
Old Jan 10, 2022 | 07:50 AM
TOM R's Avatar
if you dont see any rubbing the bearing could be bad imo
Old Jan 10, 2022 | 08:01 AM
DBLDisco's Avatar
Thank you for the reply ', I have never heard a bearing make such a high pitched noise have you heard anything like that before?,
jdbayer
Jul 16, 2020 02:18 AM
TRIARII
Nov 15, 2015 10:25 AM
sidescrollin
Dec 11, 2013 05:14 PM
chadil1ac
Jan 8, 2013 11:04 PM
mherson
Oct 26, 2009 08:11 PM
