Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Coolant Leak When Engine Off
Old Jan 21, 2023 | 11:06 AM
gb_junkie's Avatar
Default Coolant Leak When Engine Off
Hi all - got a weird one. Replaced my coolant expansion tank months ago with a Lucky8 one, but ever since then - most of the time after I drive the car, I'll see a small quarter to half dollar size puddle of coolant on the ground by the driver's side CV joint/splash guard...but only after the car is sitting with the ignition off...it doesn't leak when the car is running. The car doesn't overheat. A/C and heat work, not hearing any gurgling sounds. After removing the under shields, I am still not able to pinpoint where this small leak is coming from.
Any ideas of where to look?
Old Jan 22, 2023 | 04:35 PM
Best4x4's Avatar
Get a pressure tester on it and put 16PSI on the system. You should find the leak.
Husker
Nov 4, 2019 07:42 PM
fleacz
Sep 18, 2018 01:21 PM
benc988
Jan 17, 2013 08:15 AM
RoverRookie
Sep 9, 2009 07:00 PM
