Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Engine system fault
Old Nov 4, 2021 | 12:25 PM
Patrick Cox's Avatar
Default Engine system fault
Have this fuel problem with 2007 L320 V8 diesal , overtaking and engine loses power.
Fault lies with P000E -00. Fuel Volume regulator control exceeded learning limit.
So after some research , there is a VOLUME CONTROL Valve on the pump ,. Can anyone help please, has anyone experianced this fault.
Old Nov 27, 2021 | 03:10 AM
Jlr TechSupp Alb's Avatar
6th Gear
I had that problem twice on my garage so far and the solutions were :
1.Re-configured the powertrain control module and did a fuel system re-adaptation
2.We wrote a different file on the PCM that we knew it had no problems and it turned out to be a faulty PCM software/script in the end of the day
if these do not work then you need to replace the oil pump, replace the fuel volume regulator, replace the fuel volume sensor or repair the wiring to the fuel volume regulator.
Old Nov 27, 2021 | 08:50 AM
When you say my own Garage , would that be you run a Garage and did this and what diagnostic was this done on please.
You see I had just bought this car and it lost power when overtaking, on my way home! So pulled in and restarted, hasn't happened since, but left this fault and no matter how many times you clear it, it comes up again. Car runs well meantime.
I have since learned that the vehicle was remapped by L/R software. The mapping was performance tune. Your experience tells me something. The garaged used Autologic , that's why I'm asking.
Why would you need to change the oil pump and where is the volume regulator and volume sensor.I suspect the mapping may have upset the settings on fuelling..
If you get a chance I need to talk further. Cheers Pat
Old Nov 29, 2021 | 07:49 AM
6th Gear
we just ran a normal diag test the same code came up and the 2 solutions worked perfectly fine and we never resorted to part changes. Now you said your car had some re-mapping so that can also explains a lot but in my case we never work with tuned cars because that type of stuff is not so popular over here so yeah forgot about the tune part. Try and write an original file in you PCM and if you still got problems then the tune might have done some damage.
Old Nov 29, 2021 | 08:02 AM
Thanks for that, yeah the tuning was done with the last owner but then sold the car back to garage that did it. Then I came along!
So that might be my option to remap with standard.
Thanks again will update later.
Old Nov 29, 2021 | 08:33 AM
Sorry repeated previous reply by mistake.
Old Dec 19, 2021 | 02:20 PM
OK , I think the fault lies with the inlet manifold , its cracked , any guides out there to replace would be useful.
Regards Pat
Oh well that will be a No then. RRS has been rebuilt now twice , had a leak off pipe not quite home! Still not happy with it so further investigations needed.
Old Jan 2, 2022 | 12:02 PM
This would be the problem , I think , others are a cosequence of it .
Anyone out there please, I have just fitted a new inlet manifold and I get these faults after the rebuilt , I tried to erase on Gap but its not happening . I have checked all the plugs I had disconnected but nothing obvious there either. Sorry about the size of pics ,I don't know how to resize.
Old Jan 3, 2022 | 06:09 AM
My pics are so big I couldn't find a space to write something LOL.
Some good news and some bad ! Fuse 37 cleared the faults in the pictures. Bad news is I still have the P000E-00(2F) CODE , does seem to be one CODE I cant help with on here.
Although the car is running a lot smoother.
Old Dec 23, 2022 | 12:58 PM
Can anyone point me to where the Fuel volume regulator is fitted please V8 3.6 Diesal
RRM
Range Rover L405 (Fourth Gen)
Dec 27, 2020 09:22 AM
Chesley
Jun 28, 2019 11:34 PM
Steve Selyutin
Apr 14, 2019 08:37 PM
