Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Help with window regulator
Old Aug 19, 2020 | 02:57 PM
Christian James Lhuillier's Avatar
Default Help with window regulator
Hi all. I have searched and I can’t figure out how to release the front passenger window from the regulator so that I can gain access to a failed lock actuator. All the videos I can find show the back window which only has one clip. The front has two and I can’t seem to release either of them. Any help would be greatly appreciated!
Old Sep 19, 2020 | 04:16 PM
Ken Passey's Avatar
hi I have recently replaced the passenger front door latch I had a problem un clipping the glass from the regulator. I read a guys report where he left the glass in the clips and un bolted the whole of the regulator and it drops down in the door skin about 2 inches.. this I did and you can indeed access the two white nylon clips which hold the glass. Once unclipped tape the glass up in its closed position..move the window regulator forward to give you room, then attack the cables that hold the latch bit of a bastard to do.. took me 5 hours.
NabisOne
Sep 4, 2013 12:20 PM
CANAMDiscovery
Mar 20, 2010 11:29 AM
outback96
Dec 13, 2009 05:38 PM
808Disco
Sep 27, 2009 10:23 PM
MJL1961
Sep 9, 2009 05:00 PM
