Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Supension modul
Old Sep 19, 2022 | 10:15 AM
Okkin's Avatar
7th Gear
Default Supension modul
Hi there .
Maybe this question has already been asked in the past, but there are so many topics that I can't find, so I'm asking a new question.
I'm looking for the suspension module on a supercharged 2011 RRS. the warning light displays a suspension fault even though they are new.
Can you tell me where to find it?
Thanks in advance.
Old Sep 19, 2022 | 10:17 AM
adigerol77's Avatar
It could be the ride height sensors but you're saying they've all been swapped out, is the car drooping anywhere? It could also be the air compressor, faulting.
Old Sep 19, 2022 | 10:35 AM
Okkin's Avatar
7th Gear
No, the vehicle remains at the correct height, its road behavior is correct.
I would like to find the module to check the connections and inject WD40 to drive out the humidity, I live in Panama and there are a lot of them here.
Old Sep 19, 2022 | 12:13 PM
adigerol77's Avatar
Can you pull codes, OBD2 scanner?
Old Sep 20, 2022 | 07:30 AM
Okkin's Avatar
7th Gear
Yes I have .
Old Sep 20, 2022 | 10:09 AM
adigerol77's Avatar
What codes are you pulling up?
Old Sep 20, 2022 | 11:38 AM
Okkin's Avatar
7th Gear
I connected the software while the light was on and no code appears.
Old Sep 20, 2022 | 12:23 PM
Okkin's Avatar
7th Gear
But I would like to know where the suspension module is placed in the car to inspect and clean it. I solved another problem this way.
Old Sep 20, 2022 | 01:23 PM
adigerol77's Avatar
I believe each wheel has its own sensor.
Old Sep 30, 2022 | 12:21 PM
salvine's Avatar
I believe its located under dash on drivers side
adamw412
Sep 13, 2020 09:49 PM
kwackwacker2
Jun 2, 2017 10:42 AM
petergeraerdts
Feb 14, 2016 05:22 AM
jakethekid
Nov 18, 2013 12:47 PM
rcharrette
Feb 22, 2013 09:49 AM
