Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Whining sound engine bay.
Old Jun 21, 2018 | 06:56 PM
Mo6's Avatar
Mo6
3rd Gear
Default Whining sound engine bay.
Can someone help me. I have a 2011 range rover sport Supercharged. It has 99k miles on it. Getting a oil change this weekend. This noise started a week ago and when it's cold in the morning it takes it a little to start. When you kill engine it keeps sounding until fully stopped and all pulleys stop. It's not the suspension.here is a link to the sound
Old Mar 20, 2020 | 03:55 PM
Roverparts's Avatar
I know this is an old thread but experiencing same problem/noise Did you figure out what it was?
Old Mar 20, 2020 | 05:17 PM
Mo6's Avatar
Mo6
3rd Gear
Still not 100 percent sure but what I got out of it was I took it in to get the whine fixed and it had started to shake and smoke before I took it. Turned out it was a vacuum issue and a maps sensor issue. That my first receipt. They did some work to it and when I picked it up it was still shaky I left it there and told them Its still not right. Then they found I had a valve cover seal leak. The second ticket fixed that
First
Second
Old Mar 20, 2020 | 05:21 PM
Mo6's Avatar
Mo6
3rd Gear
Later on my gas tank a few months down my check gas tank cap came on and thru a code that did not fix with a new cap and to pass inspect I had this done incase the is info helps down the road.
Top is about rear rotor disregard top
Nav Mallhi
20
Apr 10, 2023 04:15 PM
mxdldd
Apr 16, 2022 06:37 PM
tibyABv6
Nov 10, 2010 07:23 PM
kfx4001442
Nov 21, 2008 04:35 PM
JamesLDNaylor
Sep 3, 2005 11:23 PM
