Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
2013 Range Rover 5.0 Po1308-13!
Old Sep 1, 2023 | 09:31 AM
Darinnn's Avatar
Default 2013 Range Rover 5.0 Po1308-13!
*Title should read P1308-13
I'm working on a 2013 Range Rover. It has the non-supercharged 5.0 in it. It does not say "Sport" or "Evoque" anywhere on it so I suppose a base model?
The AC compressor is getting no power and I am pulling a P1308-13 code - Short in AC compressor circuit. It is fully charged with R134A and the pressure sensor seems to be working fine. I should be getting battery voltage on the gray/red wire at the compressor connector but I got nothing. According to my diagrams this wire comes directly from the climate control module. I tried to locate this module but haven't been able to yet.
Can I get some help finding this module? Anyone seen this issue on this vehicle?
Thanks!
Old Sep 1, 2023 | 04:30 PM
Darinnn's Avatar
SOLVED
Fuse for AC clutch was blown (AC compressor coil was shorted internally). This threw me off because the fuse is not on the power circuit between the HVAC module and the compressor. There is a "AC Mag Clutch power in" circuit going into the module. This fuse is in the panel buried up behind the glove box.
EdwardRRS
Apr 10, 2021 11:20 AM
daxter1987
Apr 30, 2018 11:51 AM
lndrover@carolina.rr.com
Jul 6, 2017 08:43 AM
eugene cruz
May 21, 2017 07:52 PM
abran
Nov 22, 2013 08:24 PM
