Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
L494 Suspension Fault
Old Jul 12, 2023 | 11:02 AM
hokie.1996@yahoo.com's Avatar
Default L494 Suspension Fault
Newbie to the forum. i have a 2018 RR Sport HSE. i am getting the following codes (below). is this the compressor dying? i pulled the spare tire out and the 2018 compressor appears to be riveted together instead of clips. Can i drill out the rivets and just replace the pump?
Compressor Assembly had the following numbers on it:
HPLA 3B484 AD
107598-0 2 A2394-Q01
AMK
Codes:
C1131-92 Air Supply - Performance Or Incorrect Operation
C1A20-64 Pressure Increases Too Slow When Filling Reservoir - Signal Plausibility Failure
C1A27-13 Compressor Circuit - Circuit Open
U210A-27 Temperature Sensor - Signal Rate Of Change Above Threshold
Tnlr4
LR4
Oct 20, 2021 12:35 PM
Stonefly
Sep 14, 2016 03:50 PM
ImagClaw
Apr 29, 2015 10:39 PM
alti
Oct 25, 2013 10:45 AM
Stillwaters
Jun 12, 2011 04:39 PM
