Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
L494 Tire Pressure sensor (TPMS) Question
Old Jan 1, 2020 | 01:11 PM
RRJon818's Avatar
Exclamation L494 Tire Pressure sensor (TPMS) Question
Hey guys, i was wondering if there is any special way to install tire pressure sensors on the L494. I have a dead drivers side tire pressure sensor and i have purchased a new one online. Does the tire pressure sensor just get installed and automatically show up on the car's computer? Or does there have to be reprogramming done? Any thoughts? Please help. Thanks!!
Old Jan 13, 2020 | 01:47 AM
Chinskij's Avatar
8th Gear
Take it to tire shop have it installed and just drive it.
Old Jan 18, 2020 | 08:06 PM
RRJon818's Avatar
So i just had the tire sensor installed and drove the car for about a mile or two. Error message is still on the dashboard. Is there any specific amount of driving i should be doing? Maybe something else is wrong/broken?
Old Jan 26, 2020 | 10:47 PM
Brandon318's Avatar
From the factory manual...
Old Jan 26, 2020 | 11:35 PM
RRJon818's Avatar
thanks, but my sensor is not automatically getting noticed by the computer after driving. Im guessing my sensor is defective? It is an aftermarket one for range rovers, but i highly doubt it since its new. Could the problem be something else? Maybe the tire sensor module? The dashboard is still able to show tire pressures for the other tires, just not the drivers wheel. How would i be able to find out? Thanks so much!!
Old Jan 27, 2020 | 05:14 PM
DakotaTravler's Avatar
The one you posted does not appear aftermarket. What exactly did you get? Your pick-up antenna thing could be bad/disconnected.
Old Jan 27, 2020 | 07:36 PM
RRJon818's Avatar
that one in the pic was not mine. but thats a good observation. Do you know where that sensor detector is located? Thanks
Old Feb 1, 2020 | 05:21 PM
LR Techniker's Avatar
Some aftermarket sensors need programmed and some are plug and play. Some of the 'plug and play' sensors still need "activated". There is also a 315 Mhz and a 433 Mhz. They are not interchangeable. Its important to know what you got.
Laurie Pope
Oct 10, 2019 10:53 AM
merlinj79
LR2
Jun 28, 2017 07:46 PM
Silver_Slug
Aug 2, 2013 07:05 PM
MJ2
Feb 16, 2011 09:03 AM
oncorhynchus
Jan 21, 2007 02:14 PM
