Squeaking worst than my mattress
RRS 2013 50k miles, when travelling slow over bumps turning corners slowly when dry and hot
the car sounds worst than an old mattress squeaking from from passengers side or middle of front not
yet found exact place, when it rains it goes completely, been to garage 3 times and they can’t find the
area as it’s always been damp or wet .
if the car was not looked after or my pride and joy it would go, the squeaking is getting worse the hotter
the day which seems weird, took it to Isle of Wight three hot days up the hills round the bends over bumps
sounded like the suspension had gone, the air suspension is fine and works fine and is not leaking,
its not that kind of sound more like jumping on a spring knackered mattress.
Have noticed on line that it’s not the first RRS to have this also.
Cheers Carl
Cheers Carl
Cheers Carl
Cheers Carl
Did they find out what caused this and fixed it? I have the exact same issue and don't know what is wrong to fix.
Hi yes was the roll bar bushes, also if you have one done get both done, also do not use a dealer as will charge you three times the amount I found an authorised independent dealer who did mine, still expensive about 500 pounds.
wittingsun
Nov 1, 2015 06:03 AM
massrrsport06
Nov 5, 2008 09:42 PM
