Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Squeaking worst than my mattress
Old Jul 9, 2019 | 05:15 PM
Mammothents's Avatar
3rd Gear
Angry Squeaking worst than my mattress
RRS 2013 50k miles, when travelling slow over bumps turning corners slowly when dry and hot
the car sounds worst than an old mattress squeaking from from passengers side or middle of front not
yet found exact place, when it rains it goes completely, been to garage 3 times and they can’t find the
area as it’s always been damp or wet .
if the car was not looked after or my pride and joy it would go, the squeaking is getting worse the hotter
the day which seems weird, took it to Isle of Wight three hot days up the hills round the bends over bumps
sounded like the suspension had gone, the air suspension is fine and works fine and is not leaking,
its not that kind of sound more like jumping on a spring knackered mattress.
Have noticed on line that it’s not the first RRS to have this also.
Cheers Carl
Old Jul 12, 2019 | 11:58 PM
Brandon318's Avatar
Cheers Carl
Is it possible that the noise is coming from the seat? If so, check out Land Rover's bulletin on the matter LTB00746NAS7.
Old Jul 15, 2019 | 04:15 AM
3rd Gear
Cheers, they now think its the roll bar bushes on the passenger side as they got them to squeak while up on ramp, so fingers crossed.
Thanks anyway.
Old Mar 6, 2020 | 11:33 AM
anesi2000's Avatar
Default Did they find out what is causing this?
Thanks anyway.
Did they find out what caused this and fixed it? I have the exact same issue and don't know what is wrong to fix.
Old Jun 2, 2020 | 03:50 AM
3rd Gear
Hi yes was the roll bar bushes, also if you have one done get both done, also do not use a dealer as will charge you three times the amount I found an authorised independent dealer who did mine, still expensive about 500 pounds.
Old Apr 7, 2021 | 07:57 PM
Coopaloop's Avatar
My 2017 RRS Diesel did the same. Even worse coming home. It would chirp twice when the car was just off and the suspension was settling.
ninjaff21
Range Rover L322 (3rd Gen)
Aug 27, 2019 08:25 PM
ep3w
May 13, 2018 01:21 PM
wittingsun
Nov 1, 2015 06:03 AM
sickws6
Oct 3, 2013 04:26 PM
massrrsport06
Nov 5, 2008 09:42 PM
