Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Stability Control & HDC Not available. Gear Box Fault. Relay Clicking on a L494.
Old 04-02-2021, 12:48 AM
EdwardRRS's Avatar
4wd High
Default Stability Control & HDC Not available. Gear Box Fault. Relay Clicking on a L494.
Relay Clicking on the Passenger Cargo Side. Stability Control & HDC Not available. Gear Box Fault.
For the past 2 weeks. The clicking is worst in the morning, or if the car has been sitting for a while. Then lesser amount of clicking when moving from a Stop Sign or Traffic Lights.
The Relay Clicking sound comes from the Passenger Cargo Fuse Box Side of Range Rover Sport L494.
Some codes Readings:
U0402-92 Invalid data received from transmission failure.
U 3003-17 (2E) Battery Voltage - General Electrical Failure- Circuit Voltage Above Threshold (Note: the Main battery is about 8 months old)
I cannot locate the Start/Stop Battery supposedly next to Rear Fuse Box in that same cargo compartment.
U0001-81 (2E) High-Speed CAN Communication bus
U0028-87 (2E) Vehicle Communication Bus A
B1412-96 (AF) Quiescent Relay Box Component Failure (This Fault is over a year old)
Thanks for your help.
EdwardRRS
01-08-2024 11:18 AM
Paeve
11-20-2020 12:16 PM
nicklaeena
01-30-2013 11:58 AM
ajh
05-08-2010 08:15 PM
dcox
12-29-2007 12:24 PM
Quick Reply: Stability Control & HDC Not available. Gear Box Fault. Relay Clicking on a L494.
