ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
Is this a good CB Radio?
Old Jul 12, 2009 | 08:28 PM
  #21
Torancis_LR's Avatar
Originally Posted by Camdisco24
Awesome! I love it, im going to mimic that setup. Thanks for taking the time to post pics, and thanks to all others for the VERY helpful input.
Yep, anytime.
Tip: Pop out the light on the bumper too have more access room underneath the bumper.
Old Jul 12, 2009 | 10:19 PM
  #22
Camdisco24's Avatar
Originally Posted by Torancis_LR
Yep, anytime.
That brings up another point, how did you run your wires through the cab?
Old Jul 12, 2009 | 10:47 PM
  #23
Street Wolf's Avatar
Bwahahah...hahah..ha.... ....
-_- <--- Serious face.
Eh... let me dig up some pictures first.
Old Jul 12, 2009 | 10:54 PM
  #24
I have my CB mounted to the backside of my center console, so the way I ran mine was pulling up the passenger side carpet on the front and back doors for access.
Running the cable from the CB to underneath the passenger seat and into the carpet all the way back to the passenger side cargo box. Underneath that box to the very back door using the vent as a access point, then further on as seen in the pics.
Old Jul 12, 2009 | 11:19 PM
  #25
I have yet to install the Cb radio but Street Wolf has the pics!
Old Jul 21, 2009 | 12:55 PM
  #26
Camdisco24's Avatar
Guys, I just ran into a problem, my antenna wire came in the mail yesterday and it fits the CB but not the antenna... Do i need to buy some sort of adaptor or have I done something wrong. Here is my set up, dont know if this helps...
The good news is, I have the CB wired up (my first successful wiring job) and the antenna is in place. Now I just need to firgue out this antenna wire situation and I'll be ready to go!
Here's how the antenna looks:
Old Jul 21, 2009 | 01:45 PM
  #27
AK Rover's Avatar
The mount you have uses ring terminals to connect the coax to the antenna mount. I'm assuming the cable you got has the same connectors on both ends. Cut the end off your cable at the antenna and strip off about 1.5 inches of the black outer shielding. Inside you'll find the braided shield, then a plastic isolator and then the center conductor. Pull the braided stuff off enough that you can twist it back together off to the side and that goes to your ground (I used one of the mounting bolts for the antenna base). Next you'll want to expose enough of the center conductor so you can put a ring terminal on it. Once you do that there should be a small screw that came with the antenna mount that will go through the ring on the center conductor and into the bottom center of the mount. Essentially what you want is the end of your coax to make a Y with a ring on the center conductor and a second ring off the side on the braided shield. I'm not good at explaining things so I hope this helps.
Old Jul 21, 2009 | 02:59 PM
  #28
Camdisco24's Avatar
Thanks AK, thats perfect. I do have the kind that has the same connectors on both sides, so that explains it. Thanks!
dogstarsix75
Apr 24, 2020 01:33 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Disco TN
Jan 18, 2009 09:42 AM
