ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
My new limb risers
Old Jun 25, 2011 | 09:04 AM
hilltoppersx's Avatar
i put them on because some of the trails we go thru are really tight with pine trees and my trail stripes are plentiful, but i rather now have the branches continually hit the windscreen or come in my window. eventually i plan on putting lighting on the rack so i will have to think about protecting them from being bashed in. if i put a spring in there im thinking it will never be taunt and if it is then a big branch would just max the spring out and any pressure that would be on the rack in the current setup would still apply. at some point with a spring or not i think the pressure from a big enough branch wouldnt actually take the roof rack off but shear the eye bolt in the rack.
Old Jun 25, 2011 | 01:09 PM
antichrist's Avatar
A properly sized drawbar spring will keep tension.
They act like a shock absorber. Saying they won't do any good because once they stretch the force will be the same is like saying air bags don't do any good in an accident. It's the same principle, aside from one being compression forces and the other tension forces.
Old Jun 25, 2011 | 01:23 PM
Tom how do you do that calculation? wouldn't i need to test the tension of the cable when taunt to figure out the load amount for the proper fit spring?
Old Jun 25, 2011 | 03:43 PM
antichrist's Avatar
Most places that sell them, well, the good places, let you choose a spring based on various values.
Drawbar Springs
If you want to get exact, you could always hook a spring scale inline in the riser to get the load range.
Old Jul 26, 2011 | 11:47 AM
just like i said in the beginning of this page. we went thru some very heavy brush. they held up great, but idiot me was going to fast and i hit a huge branch and it sheared the eye bolt on the rack.... just as i thought it would. im going to replace it and then see if i can get some springs to put in there.
Old Jul 26, 2011 | 03:51 PM
Chris-bob's Avatar
You had fun though, right?!?! That's all the matters!
Old Oct 5, 2011 | 09:26 AM
just an update... sheared another eye bolt on our last trip.... im buying springs now, hopefully it will prevent putting that much pressure on the eye bolts. I have been using thin eye bolts because that is all that will fit thru my roof rack tubing. The tubing is quite small.
Old Oct 5, 2011 | 09:33 AM
im thinkin 2 of these
http://www.mcmaster.com/#catalog/117/1202/=ecxnu8
9630K4
or
9630K1
roverlax2
Jun 5, 2022 11:08 AM
yloDiscoII
Aug 3, 2010 05:58 PM
rj95lss
Feb 6, 2010 09:27 PM
jycsalas
Jul 10, 2009 07:12 PM
Street Wolf
Apr 8, 2009 06:31 PM
