Series I, II, IIa, III Land Rovers For all Series Land Rovers
Can't remove rear differential
Old Sep 12, 2022 | 03:21 AM
zl4dk's Avatar
3rd Gear
Default Can't remove rear differential
I'm trying to remove the rear differential of my series 2a out of its housing. The differential moves about 1/4" only and then jams. I poked a usb camera on a long cord down the axle hole and can see the serrated nut for bearing adjustment seems to be jamming on the head of one of the bolts that hold the diff on. I've built a tool to grip the bolt and turn it slightly, but this has not helped. Winding the bolt in further (the tying wire has now broken away) causes the diff to jam sooner. I've had this diff out before without these problems. I did break and axle in it (hence the need to remove it to clear the remaining broken bits). Could something more extreme have gone wrong and this serrated nut have come loose and be too proud get past the edge of the housing? The locking tab seems to be in place. It's on the short (right) side that I can see the jamming.
Old Sep 30, 2022 | 06:56 PM
zl4dk's Avatar
3rd Gear
OK I've come to the conclusion that the serrated nut has come unscrewed slightly. I'm going to have to make up a tool I can fit down the axle hole to screw it back up or unscrew it completely. I wonder if anyone has one handy they can measure the diameter of this nut and the diameter of the holes I am going to have to fit into with the tool I need to make.
Old Sep 30, 2022 | 08:18 PM
generally you just pop the axle shafts out and the diff comes right out
Old May 28, 2023 | 02:09 PM
zl4dk's Avatar
3rd Gear
With a lot o brute force and ignorance I 've finally got this out. The nut had not unscrewed but was warped somehow by shrapnel from the broken axleshaft. I had to jack the diff out with nuts and bolts and the serrated nuts have some deep scour marks in them now.
Old May 28, 2023 | 02:27 PM
Harvlr's Avatar
Thanks for letting us know how it turned out.
dopedawg
Sep 17, 2015 06:31 PM
jalodge
Apr 15, 2014 03:01 PM
calebbo
Feb 14, 2011 02:20 PM
Sbonomo
Apr 15, 2009 09:54 PM
Classic89
Sep 3, 2007 09:04 PM
