Series I, II, IIa, III Land Rovers For all Series Land Rovers
series 3 dashboard switch
Old Yesterday | 08:58 AM
Morrisfr's Avatar
5th Gear
Default series 3 dashboard switch
I recently acquired a 1974 series 3. The switch on the left top in photo does not work. When I toggle it, it feels loose as if it is not connected to anything. However, when I toggle the headlight switch next to it to the middle or on position, the dashboard lights come on, illuminating the gauges. Is it possible that a previous owner wired it so that the interior lights just run through the headlight switch so that the interior lighting switch is redundant? It is a soft top so there is no dome light. It is a military version and I do know it was rewired from 24 V to 12 V.
Old Yesterday | 01:26 PM
Harvlr's Avatar
Mine was a 2A so not necessarily the same. IIRC my dash lights had a switch of its own, not through the headlight switch. Do you have the wiring diagram? It's a very simple system and won't be difficult to trace.
Old Today | 11:04 AM
XXL's Avatar
XXL
Your description sounds correct.
The top left switch is supposed to operate the gauge backlighting, and the top right is supposed to operate the running lights in first position and headlights in second position.
Given you say the left switch feels 'loose,' maybe it failed and a previous owner moved that circuit over to the headlight switch.
The two screws on the face of the binnacle are all that is needed to remove the whole assembly. Switches are available at the usual LR parts outlets if you decide to wire it back correctly.
TheEscapist
Feb 5, 2025 06:42 AM
Dorel
May 9, 2023 11:30 PM
savagekook
Apr 5, 2015 10:00 PM
Northtosouthkaz
Jun 24, 2013 04:49 PM
garover
Feb 23, 2005 05:24 PM
